D 60 death wobble, what size washer?
Discussion in 'The Garage' started by white-rhyno, Apr 12, 2004.
  1. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Ok, I searched.
    What is the size of that washer you put under the cap? I need to start saving this info. Never thought i get a d60 at the time i read it........ Or should i just not be lazy and pull the arm off and drive to the hardware store? Another question, can a guy stack two on each side?? This is only temp till i can get some money together to rebuild it.
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Home Depot,
    Look for 1/2" fender washers. They have a 1/2" hole (duh...) and are 2" in diameter and 1/16" thick. I used three washers per side and death wobble is gone...even without a stabilizer. I run the stabilizer anyways, but I did check it without.
    FWIW I had horrible DW...couldn't drive the truck over 25 mph before I put the washers in.
    rene
  3. white-rhyno
    Jan 27, 2002
    942
    Thank you, exactly what i needed.
    Brad
  4. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Where do you put the washers?
  5. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Did you put new king pin springs and bushings in the D60 too...or just add the washers to the old springs/bushing? /forums/images/graemlins/thinking.gif
    Thanks!
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Same springs and bushings...just added the washers. The bushings looked new and the springs looked like springs /forums/images/graemlins/grin.gif The D60 I bought only had 35,000 miles on it (out of a M1008)
    Rene
