D 60 RT gear pattern check
Discussion in 'The Garage' started by Bigtoe, Mar 22, 2007.
  1. Bigtoe
    Bigtoe Registered Member
    Feb 14, 2007
    16
    MI
    How does this pattern look:bow: B/L 9
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Your pattern is REALLY hard to read but it looks way too deep. Are you putting resistance on the ring gear as you turn the pinion to take a pattern? Try thinning your paint with some gear oil, it will take a better pattern.
    Try removing .010" from the pinion shim and post up another picture.
  3. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    pinion is far too deep, take .010-.015" or so off the pinion and run the pattern again with about the same backlash.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    She likes it deep, but that is overdoing it.
  5. Bigtoe
    Feb 14, 2007
    16
    MI
    Its about 3/16 from the bottom. what do you look for???? How do you knock the bearing race and oil slinger and shims out without bending the shims????? all out of shims. I'll run it again with white and see what it looks like. I tryed yellow and added oil and stuck hammer handle by the ring gear for drag and you still can't see it very good.
  6. 1977k5
    May 26, 2003
    9,996
    134
  7. readymix
    May 30, 2004
    6,706
    26
    NO NO...
    Remove .012 for a start. Then when you get close add or remove in .002 increments.
    Too deep = remove shims
  8. Bigtoe
    Feb 14, 2007
    16
    MI
    I think I got it I'll remove shims and post again when I think I got it right.
  9. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Thats one of the pain in the ass things about regearing, not only of course constant shimming combos and rerunning patterns which is to be expected but with any dana axle is the issue of having to remove the bearing without damaging it. Thats why setup bearings are really nice, they simply slide on and off until you have the pattern where you want it. Then you can press on the real bearings and hope that the pattern comes out the same. They have some clamshell type removers that are supposed to not damage the bearing upon removal but I have heard they are not always full proof. Your on the right track just keep at it, it will pay off in the end. You want to pattern to be as centered as possible, it took me a couple tries until resident gear guru readymix helped me out. BTW, your gross ready, but ah well I had the same problem, I like to give it to em deep.
  10. 1977k5
    May 26, 2003
    9,996
    134
    Wow, I can't believe I wrote that.
    You (readymix) are very right, take ~.010" shims from your pack and see how it looks.
    My bad :doah:
  11. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    Kudos to both, for posting correct info, and graciously accepting
    corrections.:bow: :bow:
  12. Bigtoe
    Feb 14, 2007
    16
    MI
    OK I removed about 15 and used white oil paint. This time I laped out the old races,bearing and nut so there just snug because the pinion threads were starting to get bad from useing the nut to press it together. Hows it look know?????:bow::bow:
  13. Bigtoe
    Feb 14, 2007
    16
    MI
    OK back lash 9 and 48 under the pinion. Hows that look????????:bow::bow::bow:
  14. readymix
    May 30, 2004
    6,706
    26
    Look better but it still appears to be a little too deep.
  15. Bigtoe
    Feb 14, 2007
    16
    MI
    remove 2 or 5 do you think
  16. 1977k5
    May 26, 2003
    9,996
    134
    I'd say .002". You're pretty close with that last pattern :D
  17. Bigtoe
    Feb 14, 2007
    16
    MI
    OK Back lash 7 and 45 under pinion how does that look?????? ready for the mud???????:bow::bow:
  18. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Looks pretty damn good. I'd probably pull another .001 out and see if it looks better. By now you've gotta have the disassembly/reassembly down to 15 minutes or so....
  19. Bigtoe
    Feb 14, 2007
    16
    MI
    I could do it blind folded.:eek1: When I pull the pinion out the test bearing race falls out. The only thing is if there a big difference change when I put the new bearings and races in.
  20. 76zimmer
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    persistance will pay you dividends. great work.
