D-60 ster. block hole dia.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BAD4WD, Jun 26, 2002.
  1. BAD4WD
    BAD4WD Registered Member
    Feb 4, 2002
    63
    Sonora
    Does anyone know the center hole dia. for the spring for a D-60 ster. block. Thanks ,Dave........................
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if no one replies you can grab that from a gasket,
    though it is real easy to pull a cap to measure
  3. topless1tonk5
    topless1tonk5 Registered Member
    Dec 10, 2001
    98
    littleton co.
    ill get that size for you, i have an extra one laying around /forums/images/icons/smile.gif
  4. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    I've always used a 2 1/8 hole saw for all the holes in blocks or arms that I have made. Although this is slighty smaller than stock, it helps to keep the spring in the proper place. Hope this helps,
    Mike
  5. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    So, how many of these are you making? I was thinking of doing the same thing to temporarily fix mine!
