D-Max SAS ????
Discussion in '1992-Present Chevy & GMC models' started by 1967k10, Feb 5, 2006.
  1. 1967k10
    1967k10 1/2 ton status
    Nov 21, 2005
    1,728
    Nebraska looking for D60's
    Anyone do one yet? I'm looking to do my 01' but want to get some ideas on what to use for brackets and how to keep in to less than 6" of lift. It's my DD and Tow Rig so it can't be down too long. Building brackets and fab work in no problem,I just need an idea what I will need to collect for parts other than a 78'/79' Ford D60,springs,brackets,ect.What do you use for a steering setup on these new trucks?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    pretty sure ORU is converting these trucks.
    i think a d60 from a 87-98ish f350 would be a better choice as the spring pads are like 36 inches across and line up better with the frame, not to mention a little easier to find.
  3. 1967k10
    Nov 21, 2005
    1,728
    Yeah I know ORD has kits but they're $1300 and for that I can get a D60,52"s,and build brackets. The 85'+ D60 will cause some tire rub,that's why I'll use a 78'/79'.They have kits for both on ORD. I guess mainly I want to know what springs work best and if I can use rear spring hangers off a 73'-87' truck like they do on the 88-98 SAS for the rear brackets.I'll fab up the front ones.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Buy the ORU ones, copy them and return them.
  5. 1967k10
    Nov 21, 2005
    1,728
    :D That's a great idea :D .I wonder if they would take them back? If so definately worth a try.Would be easy that way
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah but then you ahve the issue of bigger tires possibly hitting your leaf springs.
  7. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I would think so, as long as you dindt have them for like a week, maybe a day or so.
  8. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    ORU is offering a +6 kit that uses 6in longer springs for a better ride and better flex. May as well copy that one and use those springs, they say they are only longer from the pin back.
  9. 1967k10
    Nov 21, 2005
    1,728
    Sounds cool. Now I just have to get a D60. I wonder if a SAS will kill my fuel milege :confused:.Any idea?
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Kill your ride. As for mileage, any lift will kill mileage, but it is a diesel, regear it.
  11. sweetk30
    Nov 1, 2004
    25,552
    545
    horseheads , ny 14845
    first its oru=off road unlimited not ord=off road design. and second wont kill the ride if thay are well made springs and or bds springs from the stock size 73-87 for the stock kits.
    and have you looked hear?http://www.setstr8.com/
  12. 1967k10
    Nov 21, 2005
    1,728
    I know it's ORU. My typo. It can't be any worse than having my t-bars cranked all the way up.
  13. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    It depends how big you are going to go also.
  14. 1967k10
    Nov 21, 2005
    1,728
    I want to stay as small as possible because it's my work truck/DD/tow rig.I pull a goosneck so I'm thinking like 5"-6" and 35"s if possible.
