D@MN GAS-SCAPS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Apr 11, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I lost the 7th gass cap today...
    I fugured after the fifth non-locking one at 9.95 a piece I'd try the locking one... you know leave my keys in it... Cant drive off w/o the keys right??? Well I forgot to leave my keys in the cap... Itr takes a while to fill a 31 gallon tank... So I drove off again today w/o my locking 15 dollar gas cap...
    SO I bought the dual set.... same key...
    Keep an extra one in the cab...
    Anyone else do this???
    Or am i jjust really bad about gas caps...
    [​IMG]See me at <A target="_blank" HREF=http://www.inhomenetworking.com/78jimmy.htm>http://www.inhomenetworking.com/78jimmy.htm</A>
  2. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Maybe you should chain it to your truck.
    <A target="_blank" HREF=http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html>http://jamonline.homestead.com/fromthegroundupK54x4/89Jimmy.html</A>
    <font color=blue>Happy Trails<font color=blue>
    <font color=blue>Wayne<font color=blue>
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    My company truck is a 93 GMC. It has a lip on it where you set the cap on. Never have lost one on it. And I fill it up every 2 days.
  4. reddog64
    Nov 9, 2000
    3,325
    my 78 doesnt have a thing to put it on...
    the chain would just get ripped off...
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I think he had a good idea. A small chain. And teck screw it on the cap and on the hinge. I might try that on my Blazer. I haven't lost one on it yet. But I am sure I will.
  6. reddog64
    Nov 9, 2000
    3,325
    It's gonna happen... trust me... someone else's turn will come...
  7. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    what i do is when i take the cap off i set in on top of the rear tire. then i know where i put it each time.
    works well, have never lost it, and i have never almost lost it.
    <A target="_blank" HREF=http://confederate9.coloradok5.com/>http://confederate9.coloradok5.com/</A>
    <font color=red>K5: Because size DOES matter</font color=red>
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    He doesn't have a gas door like the 80's models do so he doesn't have a hinge to mount a restraint on and if he puts a chain on it will most likely get ripped off or make noise. Setting it on the tire is a good idea, or just hold it in your hand...
    Murphy's Laws on Life :
    "It is a mistake to allow any mechanical object to realize you are in a hurry."
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Many cars and trucks use a lanyard of some type. Similar to what others here have suggested with a chain. Usually nylon or similar is used to prevent scratching. There are a variety of these things made which have a single loop which sort of snaps over the tank filler tube (where it pokes through the body) and has a second loop connected by a cord like thing a couple of inches long or a strip (1" wide or so). The second loop is made into or secured to the cap. You can't loose it then unless the lanyard breaks which will generally be years. On the external cap like yours, one of the models with a short 1" wide strap would probably look best. Less visible than a loop. If you can't find an aftermarket version or a factory version that can be retrofitted, it should not be too hard to make up something similar...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  10. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Our boat has a small chain that attaches to the inside of the filler neck and the gas cap. If you think loosing a gas cap on a truck is bad try a boat in the water. If you drop the gas cap its going strait down. (Our chain broke and makes filling up in the water a pain since the gas cap does not have a handle. You have to take it off with a screwdriver, and there is nothing to grab onto untill its all the way out.)
    When all else fails... Check the blinker fluid.
    78 K-5
  11. reddog64
    Nov 9, 2000
    3,325
    Confeederate...
    I do put it on my back tire...
    and alwasy run it over...
  12. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    80's Mustangs have the little plastic loop that Bad Dog was talking about...God knows there are enough wrecked Mustangs in the yards out there.
    I haven't lost one yet, but I have a routine. I figure if I put it in the same spot every time I'll remember every time. I don't put it on the tire because I would run it over too. I put it on top of the pump. I'm watching the pump while I'm filling so it stays in view the whole time...
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  13. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    Why not put it in the hole on the pump where the gas nozzle goes so when you are through, you'll have to remove it to hang the nozzle. I hang mine on the rear bumper and kinda hook it on so it wont fall off if I drive away, and haven't lost it yet.
    83K5 Silverado
    What was that bump?
  14. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I always put mine on to rule out gas splashing out as a reason as to why I get such "great" gas milage. LOL! Puting it on the pump sounds like a good idea. That way you have to move it inorder to put the pump back up.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  15. Toad
    Toad 1/2 ton status
    Mar 15, 2000
    157
    Utah
    Try one of those caps that you leave on. You just put the nozzle through.
    Another thought is that if you put your cap on your seat, you wont forget it when it pokes you in the rear while getting in.
  16. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    "you wont forget it when it pokes you in the rear while getting in."
    LOL!!
    If you ask any station about leftbehind gas caps they will drag out a big box of them... Nice way to add some variety to everyday life[​IMG]
    <A target="_blank" HREF=http://www.espen88k5.coloradok5.com>http://www.espen88k5.coloradok5.com</A>
