D*mn Thing Still Doesnt Work
Discussion in 'The Garage' started by RobbieOH, Apr 25, 2002.
  1. RobbieOH
    RobbieOH Registered Member
    Feb 15, 2002
    79
    Shoreline Washington 98133
    Okay, heres the deal. A few weeks ago I was driving the blazer, ran fine. I park it, get out, decide to move it, get back in and I turn the key, nothing happens. Nada. I get it home (thanks Gerber Towing), replace starter, starter solenoid, ignition switch, still nothing. Lights work, etc, but when I turn the key to start it absolutely nothing happens. The brake light on the dash comes on like its supposed to when you start your car, but nothing as far as starter turning, motor cranking. I'm gonna go through it with a voltage meter tomorrow or friday, just wondering if anyone has any insight into my situation.
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    have someone turn the key and you can check the voltage at the starter, the key should be the purple wire. there should be 12 volts there. if not the ignition piece on the column is toast. or a break in that wire between the bottom of the column and the starter.
    Good Luck/forums/images/icons/cool.gif
  3. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    my s15 did this , and i found that i had a short in the "inline" fuse wire.
    everything would go dead except for my lights. this wire goes to the starter.
  4. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Could be the nuetral safety switch or maybe a fusible link...
    Rene
  5. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I second the fusible link!
  6. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Thrid the fuseable link... I have had a truck do this too!
    -Dan
  7. RobbieOH
    Feb 15, 2002
    79
    Cool, I'll go throught it with my voltmeter. If it is the fusible link, is that just like a fuse thats inline with the power wire going from the ignition switch to the starter? What would make it just go out all of a sudden? Thanks for all your help guys.
  8. RobbieOH
    Feb 15, 2002
    79
    Wait a minute, I saw this thing on tv where they replaced the ignition with MSD, and replaced the fusible link with an actual fuse, like in your stereo. Couldn't I just find out the amp rating for the fusible link, and replace it with a real fuse, thereby making it easier to work on, and replace should it pop the fuse?
  9. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    Fourth on the fusible link. My truck died like that once too. My situation was brought on by the alternator going "full field". It basically cooked the fusible link and my stereo speakers.
    WIring in an appropriate fuse should be fine.
  10. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I'll throw in my vote for the neutral safety switch. I always had to crawl around on the floor of my '81 and jiggle it to get the truck to turn over.
