D@mn thing won't start right
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by teufel_hunden25, Jun 12, 2001.
  1. teufel_hunden25
    teufel_hunden25 Registered Member
    May 26, 2001
    23
    D@mn thing won\'t start right
    I've replaced both the battery and the starter on my 77 Blazer but it still has trouble starting. The starter motor tries to trun but does so very slowly. Sometimes it will start up fine but a lot of the time it struggles and just won't start at all. Please HELP!!!
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Re: D@mn thing won\'t start right
    I'm assuming it's acting like there's not enought power to turn it over. Make sure the ground cable to your battery has a good ground. Also clean the ends of the cables with a wire brush. See where that takes you.
    <font color=purple>Have you hugged your K5 today?</font color=purple>
  3. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    make sure all the cables are nice and tight, loose cables result in bad starting.
    phill
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    If your too lazy to use a wire brush, just pour coke(a-cola) on them and the corrosion will go away
    90K5
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Somewhere between the battery and starter theres resistance. Check your cables for corrosion, fraying and damaged ends. Mine did this and I got new cables and it went away.</font color=blue>
    [image]http://bbs.off-road.com/wwwthreads_uploads/53-288682-mudpit3.jpg[/image]
  6. Chris Demartini
    2,406
    Dumont NJ 07628
  7. Jason73K5
    Jason73K5 1/2 ton status
    592
    Fresno, Ca
    Get over to NAPA or Pep Boys and get yourself some 0 or 1 gage cables, they really help with current flow. Also think about going to an external ford style solenoid.
  8. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Just get new cables and be done with it. For the perfect setup, go with #2 AWG or larger.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  9. mpascino
    mpascino 1/2 ton status
    Jan 1, 2001
    557
    Connecticut
    if you want to test the starter on the truck , use a set of jumper cables from the battery and hook them up directly to the starter terminals, if it works you know your connections are crappy
    You call that dirty!?
  10. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    When does it start up fine? When cold or what? If it won't start up after it's hot and you are running headers that could be what is causing it as well.... the heat can affect starting off the headers... if so get a heat shield and maybe relocate the solenoid....might work if that is what is causing it [​IMG]
    However I bet it's the cables from what you described....my Blazer never started well until I got a better guage of wires...
    "Suck Fumes Ford Boy"
    "I love my country, I fear my government"
    <A target="_blank" HREF=http://www.chevycagal.homestead.com/steph.html>http://www.chevycagal.homestead.com/steph.html</A>
  11. Storm Trooper
    Nov 24, 2000
    4,640
    How about starting with the basics, Is your battery fully charged? They do come improperly charged or defective somethimes. Start with the easy things even if you think they are OK. Good luck with that hook the jumper cables directly to the starter thing (where eye protection for when the sparks fly).
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"6" Lift -<font color=purple>38.5's"[​IMG]....
  12. teufel_hunden25
    May 26, 2001
    23
    Thank you all. It turns out that it was a bad ground cable after all. Easy enough. Now for the rest of my repairs before getting tags hehehe.
  13. Josh
    Josh Registered Member
    Dec 11, 2000
    75
    Glendale, AZ
    What is involved in doing a remote soleniod?? I was thinking about this for another car of mine for security??
    Josh
