D*mn TRUCK!!!!!!!!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Jun 13, 2002.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Ok the truck died on the way home for lunch. I was just driving down the street and it started to shut off then I hit the gas and it tried to start again and then it just died on me. it isnt that hot here so im not sure what the hell happened any ideas of what it might be?
  2. kilroy
    kilroy Registered Member
    Nov 25, 2001
    85
    Alaska, Anchorage area
    I'm sur you know it could be a lot of things. I would start by seeing if you have spark, if you do Then check fuel pressure. also check all fuses.
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    fuel pump or filter.
  4. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Ignition module. Have it tested.
  5. wheelnut46
    wheelnut46 1/2 ton status
    Nov 27, 2001
    122
    Rhode Island
    Same thing happened to me once. Previous Owner installed a kill switch but didnt bother to use connectors on the ends of the wires. /forums/images/icons/confused.gif He just twisted the wire onto the switch. They worked loose and I got stuck. My money is on the side of electrical problems.
  6. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Check the Dist. wire..
  7. jberg62
    jberg62 1/2 ton status
    May 7, 2001
    104
    Long Island,NY
    I second the ignition module diagnosis.
    I've lived through that one. When they go...they just go.
    If you do end up changing the module you may as well go ahead and change the coil also.
    If one distributor electronic component went the next one will not be too far behind.
    Good luck and please tell us all what you find did actually cause the sudden 'cut-out'
    Jim
  8. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    I'll put in a third vote for the module. If you haven't converted your distributer, you have a 5 pin version. You also will have an ECM under the dash behind the glove box. It could be that too. I converted mine to the older-style HEI with a 4 pin module and it hasn't given me any problems since. That was about 5 years ago. When it was the 5 pin/ECM set up, I went through 3 modules and 2 ECM's in about 2 years. There are several older posts in this forum about the conversion. It's not very hard to do and it saves a lot of headaches.
  9. JimmyJuneau
    Apr 11, 2001
    811
    Juneau, Alaska
    AND the WINNER is MUDDYSUB yes it was the damn fuel pump hey only the second one in a year and a half!
