D-shaft splines ?
Discussion in 'The Garage' started by loafer, Apr 7, 2007.
  1. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I just took appart my rear drive shaft because the splined-slip-part was so bound up it wouldn't move. Is it normal for the splines to be coated with plastic? I've never seen this on factory shafts. The plastic (maybe nylon) is starting to split and come off, which is why I think it is binding. I'm affraid if I remove it all the shaft will be too sloppy though. Has anyone else run into this? The shaft is from Arizona Drive Lines and is about 3 years old. This is the third time I've taken it appart to clean/regrease the slines, but the first time I noticed the plastic coating splitting.
  2. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    So nobody has seen plastic coated d-shaft splines before?
  3. superwrench
    superwrench Registered Member
    Feb 2, 2007
    20
    Little Rock, IA.
    Not uncomon for that it is supposed to help keep them from binding up incase you forget to grease it. It doesnt always work.
  4. loafer
    Aug 19, 2003
    634
    Lyman, Maine
    OK, Thanks.
    I wound up just cutting off the plastic that was cracking or breaking off and leaveing the rest. I greasd the hell out of it and put it back together and it seams to work fine now. If it happens again I will scrape all the plastic off.
