D-tent cable adjustment
Discussion in 'The Garage' started by Justin Fleming, Sep 13, 2005.
  1. Justin Fleming
    Justin Fleming 1/2 ton status Premium Member
    Aug 24, 2005
    767
    4
    Oxford MI
    Isnt there a baseline adjustment to start with? On my old camaro we used to pull the cable to the firewall as tight as possible and then slowly push the throtle to the floor and that would give a reasonable baseline.
    Is it still down the same way on the k5 Blazer?
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what tranny is it ?
    it depends on this
    if its a 2004r or 700r4 or thm250c then you depress the lockbutton and pull the cable housing back towards firewall all the way, then let go of button and open the throttle by hand all the way wide open, it will pull cable out and make clicking noises
    if you dont set this right then you can burn the trans up, period
    there is only one setting and no such thing as adjustment on these
    good luck
