D44/10Bolt hub tool fit the D60 too?
Discussion in 'The Garage' started by guido666, Nov 15, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Does the D44/10Bolt hub locknut tool fit the D60 locknuts too? Someone told me to replace my 14Bolt locknuts with D60 ones and I just wanted to know if I needed another socket.
  2. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    you will need another socket.
  3. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Figures, nothing is ever easy. :D
  4. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The 14BFF and D60 socket are the same though. They are both 6 tooth whereas the D44/10b are 4 tooth. :D
  5. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Oh, well Kudos then, I have the 14bFF tool. :D
  6. guido666
    Feb 16, 2005
    788
    Longmont, CO
  7. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    The socket I have works on all 3, 10 bolt, 14 bolt and D60. It's got an inner part that has 4 teeth, and the outer part has 6 teeth.
  8. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    the 60 nut is square teeth and the 14ff ones i have seen are round teeth. but there is lots of axles out there might just be some others.
    also make sure the socket you buy has the cutouts for the inner nut with the pin. lots of cheepy sockets dont and will snap the pin off.
  9. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
  10. guido666
    Feb 16, 2005
    788
    Longmont, CO
    No problem, I just wanted to make sure I didn't buy what some genius "thought" were D60 locknuts. :rolleyes:
  11. 73k10sub
    73k10sub 1/2 ton status
    Jul 23, 2001
    223
    Tulsa, OK
    Socket
    Can you tell us what brand, part no., and where/how much?
    Thanks!
  12. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Yep as everyone on here has said already the Dana 60 front has 4 square slots in the nut. They look just like Dana 44/10 bolt nuts but the Dana 60 nuts are quite a bit larger. I got my socket from Autozone for about $20. The reason I used Dana 60 nuts on my 14FF is I like the pin style lock better than the bent tab style.
    Ira
