D44/14BFF Questions
Discussion in 'The Garage' started by nad, Apr 11, 2007.
  1. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Is there any way I can find a set of 3/4 ton axles to fit under my Jimmy without having to modify a bunch of stuff. Are there any specific trucks that have the same axles and spring perches and everything on them? I have a welder, and could probably re-weld spring perches and shock mounts, but I just don't trust myself.
    I would go with a D60, but I'm not planning on doing any extreme crawling, I just want to put some bigger tires on, and I've heard bad things about 10 bolt axles + 35"+ sized tires.
    Even if I found one from an old Suburban, could I just relocate the spring perches & shock mounts and bolt it right in? Or would I have to narrow it, and change driveshafts and everything else?
    Thanks for the help/opinions in advance.
  2. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Ttt
  3. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    just get a dana 44 and 14 bff from a 3/4 ton truck same year as you blazer and it will be a direct bolt in. No mods needed. I have a 75 k5 and put dana 44 and 14bff 3/4 ton from a 76 1/2 truck in.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If you get a pair of axles from any 3/4 ton truck it is a direct swap with the exception of you'll need a conversion joint for the rear driveshaft. Just make sure you get it from a 4WD truck otherwise you'll have to modify the rear shock brackets for the driver side shock to fit correctly.
  5. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    If I find a set of 3/4 ton axles, what's the biggest tire you guys would suggest on them? I'm not nearly ready to buy them or anything yet, I'm just getting an idea. Thanks.
  6. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    Aren't the 3/4 ton trucks the ones with 14B SF axles?:confused:
  7. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    Oh yeah, you're probably right. Sorry for the dumb question, but what exactly is the difference?
  8. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Not necessarily. Later 3/4's more often had the semifloat, like mid-80's and later, but the 70's ones are all fullfloat.
    For the OP, the difference is that the 14BSF sucks and you want a 14BFF. ;)
    -- A
  9. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    http://pirate4x4.com/tech/billavista/14b_bible/index.html
    That says what truck to look for, and probably the difference between semifloat and full floating. Basically, full floating is stronger and the weight doesnt rest on the axle shafts so if the axle breaks the wheel doesnt come flying off. Semi float is still plenty strong, a whole lot more so than the 10b. But I dont really have any personal experience with 14sf to really say what its capable off.
  10. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Well if it helps I have 3/4 ton axles out of a 3/4 ton 79 chevy pickup and it bolted right in to my 88 K5 with just a new u-joint. I'am now running 38.5 Interco TSL Swampers.
    BTW new U-joint NAPA part# 447
  11. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    The driver's side shock wont fit correctly? I have a 2wd 14ff that I'm putting in and was hoping it would all fit temporarily until I could reweld the shock tab. And maybe hold up to some wheelin' before I have time to weld it...I have the urge, its been too long! :crazy:
  12. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    So how can I tell a difference between a full float and semi float? And how should I know what years should bolt directly up to my Jimmy? Thanks for all the input guys, I appreciate it.
  13. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    http://coloradok5.com/axleguide.shtml
    The second 14b is full floating, the first is semi floating
  14. littleryno32
    littleryno32 Registered Member
    Jun 27, 2006
    27
    Willis TX
    Off subject but how good is the 12 bolt?
  15. nad
    nad 1/2 ton status
    Dec 29, 2005
    1,537
    Festus, MO
    ^Good question. A guy up the street has a set of 12 bolts he wants to sell me. I've heard they're not much different than the 10 bolt strength wise.
  16. 99GmcClassic
    99GmcClassic Registered Member
    Mar 10, 2007
    97
    Abington, Mass
    It's actually precision u-joint part# puj-447
    :( Aww comon there is nothing wrong with a 14sf. In most cases for 36's and under a 14sf is plenty, and its deff better than the pos 10b or 12b.
    3/4 ton 14bff are nice b/c the spring perches don't have to be moved, when you get them out of a 1 ton the perches have to be moved inward and the shock mounts also have to be relocated.
  17. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    Yeah forgot about the joint i changed mine to a 1 ton yoke. I also had 39.5 tires but changed to 37" goodyears and have no troubles.
  18. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The shock body will hit the bracket before you even get the shock to bolt in. Maybe i only had this issue because i'm running a CV rear shaft and had to rotate my pinion further up from stock which rotates the shock bracket forward and allows the shock body to hit the bracket.
    I simply cut a V into the bracket on both sides then heated the bracket and bent it backwards until the shock fit then welded the V which is now closed together.
  19. lochenjons
    Sep 13, 2006
    682
    Santa Cruz, CA
    Hmm it doesnt look like it should hit on mine...I'll have to see. You didn;t bother moving the entire bracket up? I was kinda worried about the chock being stretched farther down then it originally sits, but I guess it isnt that much.
  20. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I recently pulled my rear axle to remove and relocate the spring mounts and i also installed some 4WD shock brackets i had cut and saved from another axle.
