D44 and 38s
Discussion in 'The Garage' started by mightywhitey_k5, Feb 28, 2005.
  1. mightywhitey_k5
    mightywhitey_k5 Registered Member
    Sep 3, 2004
    74
    How well can a Dana 44 hold up to 38" swampers?
    whould i have to go cromo shafts and joints because if thats the case i would rather break by balls looking for a D60. any thing you guys may know will help, Thanks.
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    for light wheeling and easy throtle it will hold up for a little while but it will eventually break. for anything over 35's you really should go dana 60 IMHO
  3. mightywhitey_k5
    Sep 3, 2004
    74
    yup thats what i wanted to hear and thats what i want. but GOSH i dont see them any where. I would like to buy it new but dont want to fork out over three grand to Boyce or dynatrack even though there 60 do look prety cool. But $3000 plus high steer and hopfully hydro assist is not in my budget, at least i could'nt do them all at once like i would like to.
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I abused my D44 for 2 years w/ 38" TSL's and only broke 2 shafts... and I was not easy on it by any means... but it was also open in the front. I would say run the 44 until you find a 60 you can afford, but leave it open until then too! If you lock it up, you will break alot of stuff.
  5. mightywhitey_k5
    Sep 3, 2004
    74
    well i am not running a 44 now i hav a 10b i just wanted to know what direction i should go. I dont run my k5 very hard now with stock 10b's but i am working on changing all that once i get my project list all checked off. I know i am going to want to lock the front diff so i guess i prefer the 60.
  6. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    I had better luck with my stock 10 bolts then I had with my d44 both under different trucks but both with 38's. Out of 5 years of heavy wheeling with the 10b only broke 1 u joint and in the 1 year of street driving on the d44 had all sorts for wheel bearing issues and 1 broken u joint after one time in the mud. Still after owning a d60, d44, & a 10b I would risk breaking a dozen cheaper front ends rather then paying thousands for a d60 :crazy: Just my 2 cents.
  7. bigrollin76
    bigrollin76 Registered Member
    Feb 15, 2005
    26
    phoenix
    my friends runnin a d44 with 38"s lock and he's broken two axels and a hub bu thats cause he's a dumb ass. anyways d44's are all over junk yards you could probably pick one up for a few hundred bucks and it will last you till you can sve up for d60. or just run smaller tires until you can afford the 60. but definetly get rid of the 10 bolt. hope my opinion helps.
    :k5:
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Get rid of a 10 bolt front? Do you realize a 10 bolt front and a D44 front are basically the same strength wise? 10 bolt parts also tend to be cheaper and more available then D44 stuff.
    Harley
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Yeah, I'd wheel an open 10 bolt or D44 with 38's while I saved and searched for a D60. They can and do take a fair amount of abuse when not locked...
    Rene
  10. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Only differnce between a 10b and a D44 is the axle tube thickness and inner shaft spline count, everything else in the same. You wouldnt gain anything by swapping. Save yer $$ for a D60 and not waste it upgrading to chromo shafts. Run some spicer 5-760's and call it done.
    I wheel somewhat hard when I do get out wheeling and Ive only snapped a ujoint, which I hadnt changed since I got the truck so it was somehwat expected.
  11. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Looks like Boyce is right about 3100 for a front D60 with a detroit. More or less depending on what you want with it. Does that come complete with new brakes too? How about shipping? Is dynatrac more or less than boyce? Is one better than the other?
  12. AkMudr
    Dec 30, 2004
    917
    Alaska
    I'd say save yer money and find a local D60 to rebuild. You'll save alot more $$ in the long run. If you look hard enough you can even find them ready-to-run for 12-1400 or less
  13. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Any idea how much money one would save by getting a used one, new upgraded parts, and paying somebody to build it? Are we talking a couple hundred or a couple thousand bucks?
  14. AkMudr
    Dec 30, 2004
    917
    Alaska
    Yer in CA, I'd imagine theres alot of D60's to be had there with the amount of crawlers there. The amount you pay to rebuild one comes hand in hand with what kind of condition its in. With a good D60 manual you could rebuild it yerself, maybe get someone to setup the gears but everything else is pretty straight forward. I have seen guys get readytorun d60's for $1k and they had ti change the calipers and seals maybe, that doesn tset you back much.
    Theres actually a guy on Pirate with D60's for about $850, I cant remember where hes from but fro some reason southern CA comes to mind. I'll get you mor einfo when I get home..Pirate is blocked from work lol :confused:
    Sorry to get off topic. lol.
  15. skelly1
    Sep 2, 2002
    554
    San Diego, CA
    Thanks man. I'll check out pirate too. Websense sucks.
  16. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    You can also use a Dodge Dana 60 front.
  17. AkMudr
    Dec 30, 2004
    917
    Alaska
    I found 3 D60's in Ohio, All under $800, complete on Pirate.
  18. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    just run it till it dies!!!!!!!!
    :saweet:
    hehe I like to get stupid on mine, I'll jump em, bash em, twist um and throttle them till they puke..much cheaper then d-60 parts..
    when you get sick of ball joints and you think you are at your wits end with death wobble, swap in a 60...then discover the world of 1 ton death wobble!
    I had a 60 but sold it before I got the enjoyment of breaking anything:frown1:
    just carry spares and enjoy, when you start having to replace knuckles or start breaking axel housings..get a 60 and build it your self, or buy one some other sucker already dropped his $$$ in:D
