D44 Axle seals HELP!
Discussion in 'The Garage' started by bouncytruck, Jul 23, 2002.
  1. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I started to put my front axle back together when I realized that I was missing the seal between the housing and the axle itself (a PO didn't bother to put them in last time they tore it down!). According to the books at NAPA, the seal should be #13165 but it doesn't fit. I tried a national #5131 at CarQuest and it is the exact same seal NAPA has (even stamped with 13165) Does anyone know what Part Number I need to be looking for? I'm getting desparate - suns out and I want to drive the beast again!
    /forums/images/icons/crazy.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    What exactly do you mean "it doesn't fit"? The seal too big around, or what?
  3. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    Im not sure how much you know about axles, but there is no outer tube seal on a D44. Don't know if that's what you were talking about or not. If not I didn't mean to insult your knowledge. I have had friends call me all frustrated 'cause they couldn't find an outer tube seal (like on a rear axle) for their front...It's funny when they realize the seal is inside next to the pumpkin. Just a thought....
  4. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    Well, I guess I'm an insult to my own intellegence. That is exactly what I was looking for! Now I know why there were no seals when I tore it apart and why the seals almost fit. THANKS! Now I can get it back on the road.
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Do you still have your original closed knuckle axle or a newer open knuckle? That will make a difference also.
  6. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    It is an open knuckle with disc brakes. I wasn't pulling the gears, I just had the axles out to replace the ball joints. Everything in the pumpkin looks nice and clean so I'm going to leave it alone for now. The part numbers were for everything from 68-79 or something like that. Thanks again!
