D44 axle shafts
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 70~K5, May 7, 2002.
  1. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Will the stronger axle shafts from a '73 up 1/2 ton D44 swap into a '72 3/4 ton D44? Or do I need to find a set from a 3/4 ton D44?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can use any D44 shafts. The 73- shafts are actually preferable because they use the larger 297 u-joint as opposed to the 260's that the pre-73 ones use.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup, I second that....
  4. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Hub design plays no part correct? In regards to internal or external. I too would like to upgrade my axle u-joints from the 260 to 297.
  5. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Same here my current setup has external locking hubs. Are the shafts still the same as internal locking hubs?
  6. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The only hub difference that matters is auto vs manual hubs. The auto hub shafts have one extra snap ring grove on them.
    To use the newer 297 shafts all you have to change is the spindle seal. The kit that I got had a metal ring that made the old axle look like the newer one and so they both use the same seal but the older ones have to use the ring (and the newer ones throw it away). The p/n is BK1 (SKF brand) for that kit.
  7. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    Thanks!
  8. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    To add to the confusion, some late '72s supposedly got axles with the 297X universal joints. At least, that's according to Randy's Ring and Pinion.
  9. Burt4x4
    6,854
    My 72 had them (297)when I bought my rig and as far as I could tell when I rebuilt my D44 ALL the parts looked stock. I don't know for sure thouh...
  10. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    How wide are the 297s compared to the 260s? I'd be able to measure without taking it apart I think. My front is out of a '72 K20, don't know if it was early or late '72.
  11. Burt4x4
    6,854
    I don't know the measuremnts but you can tell the larger one from the smaller one with out pulling the axel.
    Go to a parts house with your rig and ask for a Spicer 5-297x Ujoint and you should beable to hold it next to the axel in your front and tell that way..
    Good luck
