D44 carrier removal
Discussion in 'The Garage' started by ktedesco, Mar 13, 2005.
  1. ktedesco
    ktedesco 1/2 ton status
    Mar 21, 2004
    365
    Colorado Springs, CO
    Does anyone have a good way to remove the carrier? I remember an old post about a way to "walk" it out but I can't find it now. Shafts are out and bearing caps are off but I can't seem to budge the carrier.:confused:
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Put a box end wrench on one of the ring gear bolts and then turn the drive shaft. When the wrench hits the case you better be ready to catch the carrier because it will come right out.
  3. ktedesco
    Mar 21, 2004
    365
    Thanks Chief, it worked great:D
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Kevin,
    Did you get everything back together? Let me know if you need any more help.
  5. readymix
    May 30, 2004
    6,706
    26
    No problem. Hope it all goes well
