D44 Carrier?
Discussion in 'The Garage' started by nicotine, Mar 31, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    what is the ring and pion gear ratio to were a dana 44 carrier has to be changed i have 3.08 and need 4.10 do i have to replace carrier?
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i belive the split is a 3.42 and 3.73. but i could be wrong. you should be able to order thick 4.10 gears is all.
    Grant
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes you will need a new carrier, the split is 3.73/4.10
  4. nicotine
    Jan 11, 2004
    116
    so with my current carrier i could install 4:10 only if i get the thick gears? is doing this bad or does it matter? /forums/images/graemlins/dunno.gif
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    If you are dealing with an open carrier, you'd be better off going to a junkyard and getting a good used carrier, ring & pinion. You have to set the gears back up anyways. /forums/images/graemlins/waytogo.gif
    By the way, the carrier split is 3.73-down & 3.92-up (numerically). /forums/images/graemlins/waytogo.gif
