d44/d60 question
Discussion in 'The Garage' started by thezentree, Nov 19, 2003.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    i just got the ford dana 60 i ordered, and i'm starting to wonder whether or not its actually a D60 and is instead a d44. the diff seems more rounded than the 60s ive seen online. anyway, did any version of the D44 come with kingpins in the knuckle? i would post a picture, but it's at a friend's house (he has a shop, i dont).
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    NO they didn't....you can also tell by looking at the lower right web when looking at the diff cover, it will either say 44 or 60 /forums/images/graemlins/thumb.gif
  3. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Well actually D44's started out with king pins /forums/images/graemlins/ignore.gif But they are easy to tell apart because they have closed knuckles and drum brakes too.
    I guess I should have mentioned this was for D44 FRONT axles in my post to be 100% acurate /forums/images/graemlins/wink.gif Wouldnt want anyone telling me D44 rear axles have drum brakes and no king pins /forums/images/graemlins/rotfl.gif
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Well actually D44's started out with king pins /forums/images/graemlins/ignore.gifBut they are easy to tell apart because they have closed knuckles and drum brakes too.
    /forums/images/graemlins/ignore.gif /forums/images/graemlins/thumb.gif
  5. thezentree
    Sep 19, 2003
    7,198
    NC
    cool, thanks yall /forums/images/graemlins/thumb.gif
  6. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    old old old cherokees and some (i think) fords came king pin and drums---i have see a 44 king pin'd disk'd open knuckel though, but i dont know if it was converted somehow.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    69 and older chevy are closed knuckle and drum, most 70-uchevy are open with disc starting for 71
    69 and 70 were conversion to open knuckle years, some open and some closed
    if its open knuckle and is disc brake then that would be what you want
    plus in 1970 the GM rear axles got 1.5" wider, so the front axles probably went longer too i imagine in order to keep the front wider like usual
    facing front of axle look onlower driver side corner webbing of diff housing look for 44 or 60 raised big numbers
