D44 front all time 4wd?
Discussion in 'The Garage' started by DirtyJim, Dec 27, 2006.
  1. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    i was looking at a d44 with all time 4wd hubs. the guy didnt know what it came out of or what year it is. the knuckles have the same steering arm as a 10b. is it possible to swap a 10b 8lug rotor / hub / brake onto the spindle?
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It depends on the spindle size. Dana 44s had 2 different size spindles with different bearings and spacings. The large spindle is the same size as a 10 Bolt. Those axles came in 1/2 and 3/4 ton trucks with a 203.
    Ira
  3. DirtyJim
    May 4, 2005
    665
    San Diego
    thanks.... it has a matching 14bff with a 203 off to the side. those were the only pieces he had left of the truck.
  4. sandawgk5
    Oct 28, 2003
    6,881
    If it has a matching 14FF should it not already be 8 lug? I would say get all of it if you can then find a 205 and you are set:D
    Ira
  5. DirtyJim
    May 4, 2005
    665
    San Diego
    its 8 lug, but all time 4wd. there is no way to switch it into 2wd. well hes got all this stuff for sale and wants it gone. i just didnt want to get stuck with another odd ball axle.
  6. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    are you saying it has slugs instead of selectable hubs? or just that its from a 203 setup?
  7. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    should be able to put lockouts on it.
  8. sandawgk5
    Oct 28, 2003
    6,881
    Sounds to me like it has slugs and is from a 203 setup. Personally I would pick it up and yes you can remove those slugs and put lockouts on it.
    Ira
