D44 front axle question - pinion related
Discussion in 'The Garage' started by heavy4x4, Jul 1, 2004.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    '79 8 lug D44.
    This has shims instead of a crush sleeve to determine pinion bearing preload, correct?
    What should I torque the pinion nut then too...just crank down on it?
    Reason I ask is this:
    There was some gear oil coming out of my pinion, but not really leaking past the seal. I took out the driveshaft, locked the hubs, put a wrench on the pinion nut, and gave it a turn. Without much effort, I was able to tighten the pinion nut (maybe 30-40 ft. lbs) The nut was obviously loose. So, I tightened it down with some locktite (didn't get out the torque wrench...but tightened it probably close to 140 ft. lbs) It's now a little "harder" to turn than before.
    Any ideas/info?
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Pull the cover and check the ring and pinion for unusual wear. You may have damaged your gears without enough preload.
  3. heavy4x4
    Aug 28, 2002
    3,270
    Anyone else have something to add? /forums/images/graemlins/dunno.gif
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Correct, jsut tighten it down. The shims set the preload. If it came loose, and you drove on them for a while, the gearset could be no good now, but if it wasnt too long it might be ok. Just tighten the nut back up til you cant anymore.
