d44 front light 1 ton?
Discussion in 'The Garage' started by original balzer, Jul 23, 2005.
  1. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    so i went and had the fluids changed in my axles. it has 4.56 gears front and rear, it has a ff14b and a d44 front. according to the title its a 3500,
    the truck does have camper special on it. did they build a 3/4 ton with 4.56 gears and label them as 1 tons? what gives?i never herd of a 1 ton with d44 front i thought for a second maybe it has a beefier rear axle but its just a ff 14b. does a stiff ride and low gears justify a 1 ton rate? by the way its a 77 GMC
    balzer
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Sure its a D44 front??
  3. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    some one could swapped the d60 out before you bought it. :eek1:
  4. original balzer
    Nov 17, 2004
    4,660
    roosevelt utah
    im sure its a d44, and i hadnt thought of it being swapped b4 i got it. now i think about it, wouldnt a 77 have a 10b rather than a d44 stock?
    balzer
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    nope, my 77 1/2 ton has a d44 under it. thats the year they changed the spindles and bearings. and after that year they went to 10blts. if you know your front wheel bearing part # it should be the long one like LM104949,set45 or somthing like that. 76-73 has the part # set37,set45
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    1977 is the first year of the D60. im guessing one of two things with your rig. they had some "1 ton" 44's left and used it OR someone swapped out the 60.
    grant
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    As for 4.56 gears, yes that could be factory too. I know that most heavy (3/4 & 1 ton) trucks that came with inline 6 cylinders had 4.56 gears and others may have to as an option.
    Harley
