D44 Hubs leak. any fixes?
Discussion in 'The Garage' started by toy4x4runner, Oct 2, 2005.
  1. toy4x4runner
    toy4x4runner 1/2 ton status
    Nov 3, 2004
    122
    Tampa, FL
    I'm running some Mile marker SS hubs up front. I just took them out and yes they're leaking water in. How do I keep them from doing that? RTV the bolts and O ring? What do you guys do?
  2. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    what torque should the bearing nut be at? I torqued it to 50lb/ft, but the bearings/races were all brand-new. So Now I have about 10K miles on them what should they be torqued to? 40?
  3. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    I figured this would be a common problem with people. ???
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I run the Mile marker SS hubs and have NEVER had a problem, period. I used a very thin layer of RTV on the gaskets and bolts.
  5. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    my guess is that more water is coming in from the other end. i wouldn't be surprised if the seal over your inner bearing was shot.
  6. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    the seal for the axle shaft through spindle is new also. I only have water inbetween the hub body and hub cover. It's not getting into the wheel bearings.
