D44 Knuckle (drivers side) - AZ
Discussion in 'Parts & Trucks Wanted' started by Hossbaby50, Feb 1, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am looking for a drivers side D44 knuckle from a chevy. I got my set of flat tops from a Jeep (or something) and the drivers side is not drilled for a steering arm.
    I don't need the passenger knuckle, just a drivers. So if anyone in AZ has one laying around from a crossover swap let me know. Thanks
    Harley
  2. Kyburbn
    Kyburbn Registered Member
    Dec 16, 2003
    61
    Rineyville, Kentucky
    You gotta watch trying to get them to match. Some had the TRE's mount with nutz up or down, and some even had the knuckles made different so one arm might be higher than the other. If you don't find one like you need I have a matched pair of flat tops from a Chevy disc set-up that hasn't been machined or drilled yet.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I have one from a 10 bolt if that will work.
    Dan
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    no, I have my 10 bolt knuckles on the axle I got off you, but I want to get a chevy drivers side knuckle that way i could go to high steer crossover if I felt like it one day. Don't think I will, but i want to keep that option open in case I do. So I have to find a D44 Chevy drivers side kncukle.
    harley
  5. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I have one from a 78 /forums/images/graemlins/thumb.gif $10 plus the ride
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I need this to be local so i can make sure that it is the right knuckle to match my passenger side knuckle. thanks though
    Harley
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Ok let me know. By the way why do you need a steering arm on the drivers side if you are building crossover? Just doing a little at a time I guess huh /forums/images/graemlins/thumb.gif
    TTT for ya
  8. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I need to replace my ball joints now, but I don't have the money for all the crossover parts so I want to swap on my D44 knuckles with new ball joints and still be able to run standard steering for now.
    Plus it leaves the option open of hi-steer down the road if I want to go that way.
    harley
  9. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Harley
    so the pass side does have steering?
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
  11. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    ill have to find one for my crossover project. as long as i can still use the rest chevrolet.
