D44 Knuckles on 10Bolt??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1bigk10, Jan 12, 2002.
  1. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    If I put my D44 Knuckles on my 10 bolt will my 10 bolt tie rod fit into those knuckles i know that on the D44 the rod ends go in through the top of the knuckles where as the 10 bolt goes in through the bottom I'm planning for the cross over steering and have everything to do it except the movivaton becouse my rig can't be down for more than a couple of days.
    I already have the 2WD power steering box and drop pitman arm D44 knuckles and another tie rod end off of another 10bolt.
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    well, let me tell ya what i did--
    i bought what i thought was an 83 8-lug d44, but after "thatK30guy" wes, broke it down to me, it ended up being a 76 HD dana 44. it had flat top knuckles, but i couldnt get the ball joints out (the knuckles were bending when the press came down!)---so, i put the knuckles, tie rod, and spindles off of my 1989 GM 10 BOLT on there and they fit perfect. interestingly enough, was that the tie rod configuration was exactly the same i.e. one long, one short, with the stabilizer hole next to the short one on the driver side. exactly like my 10 bolt was.
    so, i will have to say yes, they will fit.
    wes can give you the ends and outs, in fact, i will send you what he wrote PM'd me back in feb/mar.
    rob
    350 TBI, 700R-4, NP241, D44-14FF, 4:10's, 38.5 TSL/SX's, full conv., full cage
    <a target="_blank" href=http://www.yeild2me.rockcrawler.com>www.yeild2me.rockcrawler.com</a>
  3. 1bigk10
    Dec 20, 2001
    151
    Medford Oregon
    Thanx a bunch I'de realy appreiate it. Happy wheelin[​IMG]
