D44 outer axle question
Discussion in 'The Garage' started by ramses, Mar 14, 2006.
  1. ramses
    ramses 1/2 ton status
    Jul 2, 2004
    238
    West Virginia
    I bent my outer axle shaft on the passenger side of my Dana 44 a couple weeks ago. Someone gave me a whole D44 yesturday but I have 2 issues with taking the axle I need out of it. The 44 I just got is full time 4wd, mine has lockout hubs, and the only good axle was the one from the driver's side. I took it out already, but I cant remember what mine looked like lol. I need to know if the outer axle from the opposite side is the same and if a full time front end has the same axles. I think it will work but I just wanted to make sure before I took mine apart. Also I was thinkin, if I ever blew a hub on my truck and needed 4wd desperately, could I put the flange from the fullltime 44 on mine in place of the broken hub and have 4wd?
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup it will work..I belive the full-time axels have an extra lock ring groove but other than that they are the same.
    ANd ya why not use the full time as a busted hub replacement..:D
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    The outers are the same regardless of if they are manual or automatic hubs. Yes, you can swap hubs from one axle to the other. I wouldn't personally run 1 manual and 1 auto hub on the same axle, but I have seen stranger things.
