D44 Owners or the Knowledgable
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BowtieBlazer, Feb 5, 2003.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Is the front tie rod, drag link?? (Knuckle to knuckle connection) supposed to be bent or tapered in to where the steering stablizer hooks into it. I am curious because after much thought and comparison between the 10bolt and d44 the 44 has way different mounting points for the stabalizer and I can't seem to find pictures of a d44 from the right angle to see if the ends taper into the middle where the stabalizer connects. I am sure I could adjust the ends to make up for it, if its bent in a non OEM way but I'd rather replace it with some more beef if its that bad.... /forums/images/graemlins/usaflag.gif
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    The 10 bolt and D44 tie rods are completely different. The 10 bolt stabilizer is mounted to the end of the tie rod and at the middle of the axle, where as the D44 is the opposite. So the tie rods don't interchange the D44 tie rod should be striaght with no bends at the stabilizer mount. I took 2 pics of mine since it is not in the truck yet the first shows the stabilizer mount location up close and the second is the whole tie rod in the same position as the first pic just wide angle. As far as the stabilizer end that goes into the tie rod it is tapered and can only go in one way. Hope this helps, Ryan
  3. BowtieBlazer
    Jul 15, 2001
    2,462
    Thats exactly what i was looking for and it exactly means my tie rod is BENT! FRICKING FRAGGER FRAGGA @#$&#^&@!! Dammit...more money into the axle swaps..... Mine if laid flat on the ball joint botooms on each end would made a nice fighter jet V inwards toward the axle tube and steering stabalizer. Thing is there is no noticable notch where they would have run into something and it bent it...its like perfectly bent evenly from one end to the other starting at the steering stabalizer both ways. I guess this would be the weak link on the length of tie rod and if anything pushed in on it...its natural tendency would be to bend at that weak point.....any other insight?
  4. BowtieBlazer
    Jul 15, 2001
    2,462
    Upon looking at the secnd picture, yours may have some bend...is there any way you could get a shot of it flush to a board grease fittings toward the board, ball joints away?? Any other flat straight plained surface would work...
  5. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Mine is bent a little the guy i bought it from said he bent it some pulling it out of the truck. Also there is a little offset in the flat part where the stabilizer stud slides in to keep it from binding. I can get that pic still though if you want.
  6. BowtieBlazer
    Jul 15, 2001
    2,462
    If you would please! /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif
  7. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I'll get it today!
  8. BowtieBlazer
    Jul 15, 2001
    2,462
    /forums/images/graemlins/thumb.gif SAAAWEEEETTT!!
  9. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    I used the line in the lenoleum as a guide for you. The first pic is on its side, second is standing up, and third shows how much mine is bent up. Hope these help.
  10. BowtieBlazer
    Jul 15, 2001
    2,462
    Thank you so much! Thats exactly what I was looking for...I was getting frustrated using my photo editing to try and draw a straight line next to the other pictures to get an idea. It has almost the exact bend that my tie rod has.....The first and third pictures are most helpful. Thanks again! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif
    A step closer to making the Midwest Spring run /forums/images/graemlins/grin.gif /forums/images/graemlins/deal.gif
  11. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Glad I could help makes me feel I'm earning my place in your camper I just totally rebuilt my D44 so if you have any other questons feel free to PM me.
  12. BowtieBlazer
    Jul 15, 2001
    2,462
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/deal.gif
