D44 parts breakdown?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Thumper, Jan 30, 2004.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I am looking for specifically the pinion setup...
    I know from the inside out it goes:
    Pinion gear, shims, bearing, bearing, slinger, yoke, nut.
    Am I missing anything? I recently replaced an inner bearing on my pinion, and now it sits loose in the housing. The nut is tight (as far as I can get it), but it still has slop in and out (about 1/4" or so). I dont think I can add enough shims under the inner bearing to tighten things up... maybe I am missing something?
    Thanks!
    Mike
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Isn't there two seperate sets of shims? One set for pinion depth (position) and one for pinion bearing preload?
