D44 problem...
Discussion in 'The Garage' started by OrangeCrushK10, Oct 25, 2006.
  1. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    I'm thinkin' it's a bad wheel bearing, but lets see what the general opinion is.
    Just finished installing my D44 into my s10 blazer. I took it for a test drive around the block and after a few hundred yards it starts making a "popping" noise from the wheel. I can kinda feel it in the steering wheel (I have a rathar loose steering setup) and feel it in the floorboards decently. On the way back home it slowly gets worse and starts squeeling a bit. Also it is worse when braking or turning.
    There ya go. I need new wheel bearings or what?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Do you have hubs? It could be a wheel bearing, but it could be a bad u-joint or hub as well. Take it apart and find out, anything that makes that kind of noise should be pretty apparent.
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Jack it up and spin the wheels by hand, listen and feel for anything abnormal. Also, try rocking the tires at the 12 & 6 o'clock position. There really shouldn't be any play that you can feel by hand. It does sound like either a bad bearing, or ball joint to me.
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Sell it and buy a Jeep......or maybe a Ford...Then it'll work without requiring maintenance :grin: :whistle: :rotfl:
  5. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    ujoint binding up to me. if you have lockout hubs locked in or flanges and it spins all the time i bet its that.
  6. OrangeCrushK10
    Jan 25, 2003
    1,425
    replaced the wheel bearings, problem solved. From the wear on the spindle it looks like it was the outer bearing.
    And Burblover? The D44 is from Jeep. It's out of an '84 Grand Wagoneer and now sitting under my '89 S-10 blazer. :D :p:
  7. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    IIRC, that would make that the widetrack version of the D44, which is slightly wider than the standard Jeep D44. Also a little beefier.
  8. OrangeCrushK10
    Jan 25, 2003
    1,425
    Yeah. Also has that built in vacuum disconnect in the diff. I'm thinking it'll be neat to make that work with the S-10's vacuum disconnect system, but it may also be a big mistake. :rolleyes: I guess I get to find out.
