d44 steering block question
Discussion in 'The Garage' started by bad_bo_ti, Jun 10, 2003.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    i am wanting to get 2 steering arm blocks made for me when I go to histeer and was wondering if anyone had a picture/drawing with measurements for the whole block, 3 mounting holes, curve for ball joint etc, would appreciate it alot, thanks, chris
  2. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i bought mine from avalanch engineering AKA poisen spyder cutoms...the important thing with this is to make sure you key the block to the steering arm so they lock tegether /forums/images/graemlins/thumb.gif..you also can cut off 2 stock steering arms for your blocks but you would hafta fill the cone holes with weld and re drill out the holes...
  3. bad_bo_ti
    1,027
    OhiO
    if i get some made would it hurt to just have a GOOD welder weld the block and the arm together? i am thinking i might need like a 2in block for it, but i might sacrafice and go 1in to be safe, should my draglink be straight (parallel) with the tierod? or does it really matter? thanks, chris
  4. leadfoot067
    May 14, 2001
    1,563
    well i broke off the 9/16 studs with a 1" spacer that wasnt keyed so i went with 5/8 studs...with 2" i would strongly recommend the 5/8 studs and welding them together accomplishes the same thing as what ive done with the keyed block... in my opinion /forums/images/graemlins/thumb.gif
  5. bad_bo_ti
    1,027
    OhiO
    what all is involved with putting in 5/8 studs? do i have to drill and tap the knuckle again and drill out the steering arm and block and then drill out the cone washers? also, if i run hydro assist would it be ok to drill another hole in the drivers side histeer arm to hook the ram too? thanks, chris
  6. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    PM Muddytazz - he machined my D44 knuckles for 5/8 studs, so he knows first hand what is involved with this mod /forums/images/graemlins/cool.gif
