D44 u-bolts the same as 10b??
Discussion in 'The Garage' started by 85mudblazin, Jul 26, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Will u-bolts from a D44 work on a 10b??
  2. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    aren't there 2 different ubolt setups for 44? The 2 5/8"(i think) and 3" tube setups. 3" will work fine I believe, or did I install a D44 with the wrong ubolts?
  4. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Yeah. I'll go check tomorrow. I know the spring plates are different. It is common practice to use the same U-bolts from 73 to 91 but they weren't the same from the factory. I always thought they were until I took the front axle out of my 73.
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I very well could be wrong here but my 73 u bolts would not fit a 10 bolt but my bro in laws 78 44 u bolts fit an 84 10bolt just fine
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    The earlier D44's with the small bearing spindles and pass side flat tops usually have the smaller tube diameter and were used until some time around '75 then they switched to the larger tube D44 that is the same as the 10 bolt tube size.
  7. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Yup and I found out the hard way!! Had to miss a weekend of wheeling when I found out the U bolts on my 73 K20 werenarrower than the one on my 81 Blazer. I was swapping the lift on the blazer to the K20 and in my neighborhood I cant keep a vehicle on jack stands so I had to delay the work till I got another set of U Bolts. :doah:
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thanks for the info.
    I am mainly interested in the u-bolt that goes around the housing, anyone know about that one??
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Second-design years (77-on up) will work on your 10 bolt. First design (76-and older) use a 2.75" tube diameter compared to the 3" newer ones.
