d44 u-joints
Discussion in 'The Garage' started by slimlynn1, Feb 3, 2004.
  1. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    I'm replacing my Dana 44 u-joints and had them pressed in by the shop. they used the ones with the grease fitting in the end, it is not a zerk fitting but some other type. The problem is that they wont fit in the knuckle. Can I remove these and replace them with zerk fittings or will they get broken off? Or can I remove the ones that are on them and then put them back on after I slide the shaft in? Thanks
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah, just take the fittings off, slide the shafts in and put the fittings back on. Just make sure not to over-tighten them as they can strip out easily /forums/images/graemlins/waytogo.gif
