D44 Ujoint swap???
Discussion in 'The Garage' started by 72jimmycst, Sep 10, 2005.
  1. 72jimmycst
    72jimmycst Registered Member
    Sep 5, 2005
    17
    Rapid City SD
    Is there any way to get around taking your hub all the way apart just to swap ujoints on a dana 44 front axel? Why can't you just unbolt the spindle and slide the axle out.
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    You cannot unbolt the spindles without removing the hubs/rotors, and you cannot remove the knuckles without the axle shafts being removed. No way around it, you have to strip it down to the knuckle :doah:
  3. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,025
    850
    Pinckney, MI
    If there was another way to not take off the hubs, and was easier then taking everything off it would be done all the time. Most the half ton guys can change a shaft in 20-30minutes. I'm more like 40ish, but i'm working on it :)
