D44 verus GM 10 bolt
Discussion in 'The Garage' started by steedalx, Jan 7, 2004.
  1. steedalx
    steedalx 1/2 ton status
    Dec 19, 2003
    142
    Chattanooga, TN
    I am trying to find some information about which front end is stronger. A 6 lug D44 or an 8 lug GM 10 bolt.
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    The hub doesn't matter in the axle's strength so don't worry about how many lugs it has. A 10B and D44 are almost exactly the same in strength. One isn't better than the other really. The only advantage a D44 has is that it's housing is made of nodualar iron compared to the 10bolt's grey iron housing so it can handle a little more verticle abuse.
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the hub is not the only difference between 1/2 and 3/4 axles, ie 6 and 8 lug, IIRC, the 3/4 ton models have different (see stronger) knuckles.. someone correct me if im out of line.. /forums/images/graemlins/truck.gif
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    hmm, maybe your right, I thought they were the same. /forums/images/graemlins/thinking.gif
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Same knuckles, no real strength difference btw the two axles regardless of the number of lugs. There are some minor differences in tube thickness but I really think one is as good as the other.
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    same knuckles? strange how stock yota wheels fit on my 1/2ton front but wont fit on my 3/4 front Im pretty sure the 3/4's are a little beefyer BTW I know there wider becuase the use a differnt tierod
  7. Confedneck
    Nov 1, 2002
    5,236
    hey i forgot about that wheel fitment problem we had..
  8. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    I think the D44 disc brake caliper is a little better than a 10 bolt one also.
  9. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    How? They interchange....
  10. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Hmmm....I have my 1/2 ton flat-top D44 knuckles on my 3/4 ton D44. In fact, I bolted the stock 3/4 ton spindles to said knuckles. /forums/images/graemlins/thinking.gif The 3/4 ton knuckles are the same as the 1/2 tons of the same year. /forums/images/graemlins/deal.gif
  11. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Same knuckles, the backing plate and dust cover are bigger and that is the why grinding is required for most 15" wheels to clear the 3/4 ton stuff. My 1/2T and 3/4T 10B both used the exact same width tierod.
  12. Confedneck
    Nov 1, 2002
    5,236
    odd.. we put the exact same toyota wheels and tires on one front end, rolled it out, put them on the other, and they hit the knuckle where the tie rod goes in.. please explain why.. are the knuckles perhaps built different???
  13. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    What were the two front ends? There are differences in knuckles that can be found on 10Bs and D44s, however, I think that knuckles from the same era 3/4T and 1/2T are the same.
  14. Confedneck
    Nov 1, 2002
    5,236
    both 10 bolts
    one half ton
    one 3/4 ton
  15. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    You got me, I had a 1983 3/4T 10B and a 1991 3/4T 10B and the knuckles, and tierods were identical.
  16. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    How can you fit a yota wheel on a half ton axle and a 3/4 ton axle? One of them is 6 lug, the other is 8 lug /forums/images/graemlins/confused.gif
    From my experience of actually piecing together one 3/4 ton axle from three different dana 44's I can say there is very little difference. Same knuckles, therefore same tierod, and if same year range the spindles, Axle shafts, lock outs, and brake calipers are the same. Different bearing hubs, rotors, backing plates for the brakes, inner wheel bearings (I think).
    Overall they are virtually identical. The brakes are like 1/4" bigger IIRC.
  17. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I thought you didn't have to grind on a 3/4ton front when using 15" wheels. My old 1/2ton 10bolt backing plate was very close to my old 15" wheels, now with my 16.5 rims and 3/4ton 10B... there is plenty of space, like 1.5", between the edge of the backing plate and rim. I thought they were the same size? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You thought wrong. I had to grind the crap out of my 10 bolt front to make 15" wheels clear with 4 1/4 backspacing.
  19. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I wish! I had to grind considerably on the caliper and I had to bend and grind on the support bracket as well. My wheels have 4.25" BS like Tim's.
  20. jwduke
    Aug 25, 2001
    721
    The piston is supposidly bigger
