D44 vs 10b axle shafts
Discussion in 'The Garage' started by Muddytazz, Jun 25, 2005.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I'm having a brain fart :blush:
    Isn't there a different in axle shafts? Will both the inner and outer shafts swap over to each other?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I was corrected on this years ago. :D Outer stubs are the same. Inner shafts are different. The splines are cut at different pressure angles....
    :thumb:
    **EDIT: I am referring to 30 spline 10 bolts
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yep stubs and joints are the same :)
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    10 bolts have 28 spline inner shaft, D44s are 30 spline
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    You can put a D44 30 spl. in a 10B 30 spl but not the other way around. It's not right, the angles are different but it fits and works. I think it takes a combo of jeep and ford D44 inners.
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    GM Dana 44 and Corp 10 bolt have different length inner shafts.
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Correct. I have pictures of a GM Dana 44 inner vs. a 30-spline 10-bolt inner. The total length is different, the machined seal surface is completely off, and the splines have a different pressure angle. As Stephen mentioned, you can find Dana 44 inner shafts that are "close enough" in length to use but they are not a GM factory application.
