D44 wheel bearings & D60 questions!
Discussion in 'The Garage' started by Big89Burban, Oct 17, 2005.
  1. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    I'm about to order all new wheel bearings for my 3/4ton D44 swap. Gonna replace all bearings/races and brake rotors. Do the bearings usually come with the races or do you have to normally get them seperate? Also, where can I get that inner bearing that the axle rides on?(inside the spindle) One of mine is shot.
    My other question is that I am swapping a D60 in my 1/2 ton burb. What # is my stock u-joint? I've seen custom yokes for D60's and would rather run a normal "off the shelf" u-joint in case i break them or whatever. So whats stock & what is the D60 (its out of a 79 f250). Thanks!!
    Edit: I think I missed something. I was just gonna order wheel bearings for a similar year to mine but I remembered that my d44 axle is out of a 72 k20. It has the big locking hubs on it. Is there a special designation for that axle? I saw something on autozone.com like a (spicer 44-5hdf & 44-6hdf) then there was just spicer 44-6f or 44-5f?? What does that mean? Which do I have?
  2. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    my outer bearings always come with the races, the inner bearings never seem to, and I have to buy the races seperately. Could just be who I get my (cheap) bearings from.
  3. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Thats the same way I just got them from NAPA. Weird tho, races with the outside and not the inside. But I know why when i replaced them. My outside races were tore up and my inside ones were mint. More pressure on the outside ones tears them up more often I guess.
