d44 wheelbearing/spindle
Discussion in 'The Garage' started by down4thakrown, May 15, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    one of the wheel bearings in my 77 took a crap and i didnt have enough money to buy new ones. so since my blazer has new bearings with 6 lug hubs, i thought i would switch hubs out because it'll be swapped to 8 lug before it sees the road again. so when i went to switch out the hubs, they didn't fit. the hubs off my 77 d44 (which isnt the original d44, i think its outta 75/76) woulnt fit on the spindles on my blazer that has the d44 that came from my 77 p/u. the inner bearing in the hub from the d44 that's on the 77p/u was too small for the spindles on the blazer so i swapped out spindles so it would get me to work. which leaves me wondering, when i swap the 8lug hubs on to :1zhelp: my blazer, will the inner bearing be too big for the spindles i have on it? or are they the right spindles for the 8 lug inner hubs??? :1zhelp:
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The difference is 2nd design (77-up even 10-bolt fronts) and 1st design (77-back). The older ones have the smaller inner breaings but the same seals and outter bearing. The spindle kit is also the same (BK1).
    8-lug 1st design hubs use the larger external locking hub that bolts on.
  3. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    can't afford replacement bearings?
    I paid only about $60 for the bearings and seals to do both front wheels.
    Which bearing failed? If it's the same as a stock 73 then I should have an extra lying in the parts pile.
    Fred
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    If you need big bearing spindles I have a good pair I had been trying to sell but getting ready to toss.I also have the wheel bearings.
    Chris :D
  5. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    can you move the spindles with the 6 lug hubs????
    its just a few more bolts
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    so the 8 lug inner hubs should fit on the spindles on the blazer??
