d44?
Discussion in 'The Garage' started by DesertDueler, Jan 5, 2003.
  1. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I have a question on the brakes. I have a 77 Ford dana 44 that has 2 piston calipers, and was wondering if anyone knows or has done a swap onto a chevy axle. I would want to put it on my 10 bolt front. What all would I have to swap. I know you can do it on the dana 60s.
    Dan
  2. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    ttt. This axle also has a flat top knuckle, and fords factory crossover.
    Dan
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    What exactly have you got there?
    Sounds like F250 solid-axle since you mention twin-piston calipers, but factory cross-over doesn't jive unless its an F150 w/radius arms /forums/images/graemlins/confused.gif
    This is what an F250 used:
    Dana 44 complete outers will swap over to a 10-bolt. Use everything from the balljoints out. Only thing is the steering link and tie-rod might not be the right length. I can't remeber how the Ford and GM compare for track width.
  4. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    It has radius arms, so its probably a f150 with f250 outers then. All I know is the calipers and brake pads are alot bigger then my 1/2 ton stuff. Also it is 8 lug so I know atleast the outers are 3/4 ton. Would my 10 bolt axle shafts work fine?
    Dan
  5. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    The outer stub shafts are the same on the 10 bolts and d44's so they should work fine.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Make sure that your wheels will fit over that setup. The Ford trucks have had 17 inch wheels for a few years now. Getting smaller diameter wheels to fit over the brakes could present a challenge. /forums/images/graemlins/shocked.gif
  7. u2slow
    May 9, 2001
    2,217
    BC Canada
    On a GM, the stubs (outer axles) are the same length for a 10-bolt and Dana 44, but on a Ford they might be different. They use the same u-joint, so you can mix and match if needed.
    The twin-piston Ford is tough to use with 15" wheels. 2.5" backspacing is the most you can run. They're the exact same brakes you find on a Ford Dana 60.
  8. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I just am trying to figure out all this stuff before I tare apart both trucks to do this swap and it not work. The ranger I bought is on a 3/4 ton frame with 3/4 ton axles. It has a dana 60 FF rear with posi with 4.10 gears. This would save me money if it works, if not I guess I will be offroading in a ford.
    Dan
