D60/14b tire size question *re-worded my ?*
Discussion in 'The Garage' started by BigOrange90Jimmy, Jan 14, 2003.
  1. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    In your opinion, what's the smallest size tire you would run on a D60/14b and still have decent ground clearance? I was thinking a 37 or so. I want to know what the actual owners of installed D60/14b combos think.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: D60/14b tire size question
    <font color="green"> Well they came stock with tires around 33", but they're hardly worth swapping in until you hit wide 36s or bigger. </font color>
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I would say no smaller than 35".
    Yes, those axles are not required that tire size, but there is certianly nothing wrong with using them for that is ya got them.
    -- Mike
  4. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    I was wanting to run at least a 36, so I knew I'd need a D60 from the get-go. I don't feel like screwing around with a 10b only to find out that I should have spent the money on a 60 to begin with.
  5. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    i have 1 ton axles and 35s (on road tires)... no problems. As some1 else said, they come on rigs with pretty small tires... 31s, 33s etc. from the factory.
    j
  6. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Ash, the biggent prob i had with my 14 and 35's was the clearance when aired down...even with 38's it hangs low, and now with the 40's its better, but still hangs up. i am going to shave it for another inch. but like what was said, my diesel has a 14ff and has 29" tires on it. but it doesnt go off-road. On your hybrid, 36's wouldnt be too bad with the 10 bolt because of the weight, but I would go with the 60 if you can get one.
    Rob
  7. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    MY '77 K20 I had came stock with 9.50x16.5 about 29" tires. I ran some mild trails with it like that. That was a 8 lug D44 or 10 bolt front and a FF14B rear with 4.10s new.
  8. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    Rob, I'm quickly becoming a member of the "1 TON CLUB", just like you did a few months ago. I found a D60 in Tenn. for $200. You're giving me the type of answer I am looking for. I should have been more specific in my original post. As luck would have it, a machine shop is opening downtown, so he might be able to help me in taking some material off the 14b land anchor.
  9. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have 35's for now but will go larger one day, this is how i cut the lip.....
  10. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    How much GC did you gain from that?
  11. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,140
    14
    Bangor,Pa
    you get an inch of gc by cutting the lip off.
  12. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    I will be using a more crude method of "machining" mine---SAWZALL /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    its just that bottom lip thats drags...so it will be dis-missed!
  13. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I plan on doing mine with the sawsall too. And a bucket full of blades! /forums/images/graemlins/tongue.gif
