D60 aftermarket 30 spline vs 35 spline
Discussion in 'The Garage' started by hero, Apr 19, 2006.
  1. hero
    hero Registered Member
    Oct 21, 2002
    65
    Omaha, NE
    So I'm going to be changing gears in my D60. I need a new carier. I want to put a Detroit locker in, but I can't afford to buy new axle shafts, a locker and gears and be able to go wheeling this year. So what I'm wondering, is there really THAT much of a strength difference between a 30 spline 4340 and a 35 spline 4340 D60 axle shaft?
    What I'm wanting to do is buy the locker and gears and run my stock axle shafts this year. Then next winter buy aftermarket 30 spline 4340 axles. Does this seem reasonable or a waste of money? This setup would also allow me to carry my old stock axle shafts as spares once I get the aftermarket ones.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    what conditions do you wheel under? tire size? power puting down? you are talking rear axle right?
    I can't tell you "35 splines are **% stronger".
  3. hero
    Oct 21, 2002
    65
    Omaha, NE
    Mostly trail riding, so a mix of rocks and mud. Stock 350. Front axle. The tires are 44" TSL's.
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Is this a front or rear D60? The front 60 is a 35 spline inner... The outers are the 30 spline and has nothing to do with the locker spline count.
  5. hero
    Oct 21, 2002
    65
    Omaha, NE
    Doh! Ok, then that answers my question...and I'm stupid. I guess it's not an issue. Thanks.
  6. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    no worries. Just went thru the same thing.
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    with 44s? get every last spline you can get...
    j
