D60 Birfields...
Discussion in 'The Garage' started by mikey_d05, Jul 31, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    It looks like these just might make it into production...check out this pirate thread
    Some serious coin, but they'd have a lifetime warranty and I doubt you'd ever need to use it anyways.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yea I read about them.
    You have to take the knuckle off to get them in.
    I would be pissed though if one ever did break and you had to take the knuckle off.
    Sound like they are super strong though.
    I wonder if the actual shafts are any stronger then anything on the market.
  3. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Yeah, breaking one on the trail would not be a fun time.
    However, if you think about it, you pretty much have to strip a knuckle to get a shaft out, taking the knuckle off wouldn't be that ridiculous. I would think that it'd pretty much destroy the knuckle and C if the bell exploded though.
    The shafts are 35 spline 300M so I would assume they'd be comparable to CTM's junk. However I've never heard of anyone even breaking a Superior shaft, much less a CTM shaft. Time will tell, I'm not ready to overhaul my axles yet so I'll see how the tests go.
    One other nice thing about these is turning radius, if you can clear your tires, these will turn a lot sharper than u-joints.
  4. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    bobby long coudlnt break them in his machine and they operate at 45 degree angles. 2100 for them and you would never break them.
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Friend of mine told me that there is an existing CV/Birf for D60's. It's used in industrial equipment. He has seen them in person, but I've never found a listing from casual searches.
  6. HillJackCustoms
    HillJackCustoms Registered Member
    Apr 19, 2005
    64
    Indiana
    just curious but what came on the power wagons.. I know its a D60 but is it worth while. 2wd vehicle..
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you read thorugh all the posts over on Pirate, they are mentioned. I believed they were used in some RVs and such...
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, I've heard of open knuckle D70 front axles using "con-vel joints", which "supposedly" is different and "stronger" than u-jointed shafts. Anyone know anything about this? :confused:
  9. HillJackCustoms
    Apr 19, 2005
    64
    Indiana
    whats the Rear axle out of the Power Wagon. The person is telling me its a Dana 60 but i don't know if it is a good one or not. ITs a 2wd wagon... Thanks.
  10. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    start a new thread man, not hard
