d60 bolts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chevy/cj, Dec 26, 2001.
  1. chevy/cj
    chevy/cj Registered Member
    Dec 26, 2001
    6
    Chas SC
    I was wondering if you guys with d60 fronts could help me. I have successfully stripped out the bolts on the pass side of the spring pad. The damage is from my stupidity. more on that later. i've been given 2 options so far.. jb-weld studs into the holes and nut them down ,or, drill and tap for 3/4 inch studs.
    any help would be appreciated. I put 9/16 bolts in when I built the jeep. they got tight when I put them in but in the bottom of Stagecoach they took a crap. all we had was some big metric bolts so we cranked them in. I got out but now I'm in this predicament. so there... stupid I know.. I know
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    tried Helicoiling them yet?
    or weld them up and re drill and tap if you are a real good welder
  3. michaelm
    Feb 2, 2001
    872
    oh wait...
    the housing is junk you will have to send it to me for free :)
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Do what 77chev said: Heli-coil the bastards!! [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Tsk, tsk!! [​IMG] Shame on you, Michael!! [​IMG]
    BTW, if you can get this axle for free, sell it to me for $50. [​IMG] [​IMG]
  6. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Who the devil told you to use JB weld on that? They are not your friend since they are obviously trying to kill you. [​IMG][​IMG] LOL!
    Anyway, in all seriousness, I would drill out the holes and use the heli-coils as K30 and 77chev have said.
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    A heli-coil kit of that size will set you back a bit of $$$.
    I like using Thred-Sert's because they use a normal tap and not the $$$ of the Heli-Coil tap that you won't be able to use again any way.
    But if you already broke one of the 9/16 bolts I would just drill and tap it to the next size (along w/ the spring plate of corse).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  8. michaelm
    Feb 2, 2001
    872
    you have to wonder with a statement like "they got tight when we put them in"
    sounds like they cross threaded them in and it failed so they crossthreaded some metrics in on to completely **** it up.
  9. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    uh yup . i am machinst so i get to play with threads all the time ....8-32 bolts broken off in alum suck !
    Kick It In The Firewall !!
    O R D's axles
    NO BREAKAGE
  10. lasvegas
    lasvegas 1/2 ton status
    Feb 27, 2001
    122
    Las Vegas, Nevada
    I think you might want to learn what heli-coil recommends as max torque that their insert will tolerate. The one I used in my transmission mount was not to exceed some really low figure (I forget the max, but it was more than the 40 lbs. I needed for the bolt). I do not think a heli-coil type insert is made to tolerate the torque you need on the spring pad bolt and it is too important a connection to goof up. I would go with drilling and tapping the next size up or filling in with welder and drilling and tapping out the original size.
  11. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    A 5-56 tap broken in a small aluminum part sucks too...[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  12. chevy/cj
    Dec 26, 2001
    6
    Chas SC
    actually the 9/16 bolts got loose. we then put the metrics in buggering up the threads. when i got home I tried to put it back together with the 5/8 bolts and what threads were left. now they are gone. If welding is involved... why can't I just weld in a good stud? drilling out after welding is going to be the problem.. I think. Yall keep it up this is helping me out. Thanks, Rick
  13. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    Rene, I really think you mean either a 2-56 tap (.086 maj. dia.) or a 5-40 or 5-44 tap (both have a .125 maj. dia.)......or maybe a 3-56 tap (.099 maj. dia.).....[​IMG]
    I have never heard of a 5-56 thread size....[​IMG]
    As far as inserts go I would see if you have enough room to use the <a target="_blank" href=http://www.carrlane.com/product/Nav_0112.htm>Carr Lane Key Inserts</a>. They are stronger than Heli-Coils and use normal taps that don't cost a arm and a leg. [​IMG] Good luck.
    See Ya,
    Keith
    <font color=green>Born to Drive My K5</font color=green>
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  14. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    we have 5-56 taps at my shop ...oh and &lt;Rene &gt; how many did u have to remove ? i have like 15-20 to remove ppl screw their stuff up and bring it to us to fix...
    O R D's axles
    NO BREAKAGE
  15. californiak5
    Oct 25, 2000
    820
    Maybe the are a ultra-fine series. The Machinery's Handbook does not show that size and neither does the Cleveland Twist Drill tool catalog, or any of the other tool catalogs I have. I am not saying you are wrong, just that I have never heard of that thread size. I do know that the 5-40 is considered a course thread and the 5-44 is considered a fine thread for that series of screw. What kind of taps (meaning brand name) do you guys work with in your shop? I would just like to know for my own knowledge incase I ever run into having to use that size of thread in anything around here. Thanks.
    See Ya,
    Keith
