D60 Brake Help
Discussion in 'The Garage' started by Highjaxx, Sep 21, 2004.
  1. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    I'm not sure if I need calipers for 13X2.5" or 13X3 3/8".
    I'm not even sure what the second number is measuring, thickness?
    I'm trying to buy calipers and rotors and these numbers keep coming up. It's a SRW D60. /forums/images/graemlins/thumb.gif
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    I believe those measurements are referring to the rear shoe dia x width.
    I always that that the calipers were the same for a GM D60 regardless of SRW or DRW application. /forums/images/graemlins/confused.gif /forums/images/graemlins/dunno.gif
  3. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Me to. It's probably the parts guy trying to figure out through is parts "program" if your rig has a D60 front or a 10 bolt ... that would be the only time the rear shoes would differ.
    Tell him you have to 13" x 3 1/2" rear shoes.
    Eric M.
  4. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Whew..! Thought I was losing it! /forums/images/graemlins/yikes.gif /forums/images/graemlins/screwy.gif /forums/images/graemlins/thumb.gif
  5. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    You need the 13 x 3-1/2 units (JB8 brake pkg). The 13 x 2-1/2 are 3/4T units (JB7 brake pkg). One tons only used the 13 x 3-1/2 rear brakes.
    BTW, SRW and DRW calipers are the same. The only difference between brake parts is the rotor on a DRW has different diameter holes to mount it to the DRW hub asm than the SRW has for the wheel studs to go through (rotors are the same otherwise). Other than the hole diameter differences everything is the same between SRW and DRW.
  6. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    These are new ones for me. What's a SRW and a DRW, I can't even fathom? /forums/images/graemlins/confused.gif
  7. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    SRW = single rear wheel
    DRW = dual rear wheel
  8. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    DRW = Dualies?
    As in bad-ass mo-fo 5th wheel 'aulin?
    /forums/images/graemlins/crewcab.gif
  9. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    Yeah man /forums/images/graemlins/wink.gif
