d60 brake problem
Discussion in 'The Garage' started by dan johnson, Apr 12, 2007.
  1. dan johnson
    dan johnson Registered Member
    Mar 22, 2007
    13
    minnesota
    i just finished converting my drw d60 to a srw and now my brakes don't seem to line up i'll add i also did new king pins @ bearings so i had everything apart,did i put something together wrong or are the calipers or mounting brackets different in a srw front thanx in advance
  2. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    Are your caliper mounts are on backwards?? Brackets and calipers are the same for DRW or SRW.
  3. dan johnson
    Mar 22, 2007
    13
    minnesota
    are they supposed to offset in or out, i offset mine in i was afraid maybe thats what i did wrong this is my first d60. probally should have paid more attention when i took it apart
  4. 1-tonmudder
    Apr 24, 2005
    3,052
    I dont remember right now,I haven't had mine apart in a while.
  5. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Is that RTV silicone between the steering arm and bottom of the block? If so, you should take those back off and clean them off. There should NOT be anything of the such on there.
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    X2 The stuff could breakdown and cause the steering arm the become loose and possibly break the bolts.
  8. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    This was just discussed in Mannys thread. It is acceptable to put a small amount between these things and let it squeeze out. As per Mannys thread- it calls for it in the ORD instructions. Either way I am going crossover in the next couple weeks so it'll all be tore down again.
