D60 Bushing ??
Discussion in 'The Garage' started by BLZN4FN, Dec 3, 2005.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Ok so I have got the K5 back together and went for a short drive. And guess what I have?
    Ok I will tell you. I have a bad case of Death wobble wow that is some scary Sh!t I thought If I did have it I would never felt it with Full hydro but I was wrong as always.
    So I pulled the upper kingpin caps off and remover the springs and the white bushings. Question is the white bushing supost to be split? If you look at the bushing it has 5 groves on mine one if the lines have split is this normal?
  2. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    they are split if i recall right. without the split it would not be able to slide down the kingpin as it wears and the spring pushes it down. vertical grooves are normal too. i had DW in my truck and it was a bad leaf spring. it was shaped like a wavy "s" instead of a regular arch.
  3. tRustyK5
    Jul 23, 2000
    36,181
    1,388
    E-town baby!
    Ain't that a treat? Scary enough to make a grown man soil himself.
    Rene
  4. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    i will bet the springs are old. and if so get new as thay have a bad case of the saggys. thay will sag up to 1/4 " from normal highth.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I started replacing mine today but then realized I still needed to paint my ORD crossover arm :doah: . But anyhow, My bushings looked fine as did the springs but one thing I noticed was the existing bushing had a gap of about 1/8 of an or more and the new one had no gap at all just a split in the bushing. The springs where also compressed by about 1/8-1/4 of an inch.
    Just my experiences.
    Ira
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Same here.
    Get new springs and bushings.
