D60 Caliper bracket Q's
Discussion in 'The Garage' started by Hossbaby50, Jun 11, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    D60 Caliper bracket Q\'s
    What is the difference between D60 caliper brackets off a GM/Dodge D60 & a Ford D60?
    I know the spindle bolts are different (5 vs 6).
    Are the caliper brackets the same except for the bolt pattern? What else is different?
    If they are different can you safely drill the Ford knuckle & spindle to use the 6 bolts and a GM caliper bracket? Thanks
    Harley
