D60 Caliper Grind.... Is this too much?
Discussion in 'The Garage' started by odoa3, Jul 17, 2006.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    Working on grinding down the my Dana 60 calipers for the 15 inch rims. Finally got one down to where it doesn't grind. However, it sure seems thin. These seem to be quite a bit thinner than the article write up in the technical section.
    [​IMG][​IMG]
    I had to grind off quite a bit of the outside of the pin that holds the caliper off, is that going to be an issue? I just want to be sure this is going to be safe. Sure seems like I took a lot of metal off.
    Thanks for the help.
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    Its pretty damn tough to tell from your picture, but I would guess that you are fine to run it.
  3. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Sorry, the pic's don't seem to show how thin it is. Someone calm me down! I am afraid I am going to have to go to 16's, and I have brand new 15 Boggers I have never used! :eek1: :D
  4. Quackaddict
    Quackaddict 1/2 ton status
    Apr 2, 2006
    160
    Glenn Heights, Texas
    chill out, calm down, take a breath.........you asked for someone.........the pistons aren't showing so that is one good sign. All you can do is test it out, the big test is going to be when the brakes get real hot, it is a little hard to tell from the pics.
  5. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    There is less than a 1/4 inch of metal around the hole. I also had to grind a valley down at the bottom of the caliper, resulting the missing part of the pin (the ragged part at the bottom). When I resized the pic's all the detail was lost it looks like. From the outside of the caliper there is valley back up to inside of the hole. Also the outside of the caliper holder on the top is pretty thin as well. I can email full size pic's if someone has done this and is willing to check it out.
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    This is my expirance ginding calipers it seems the chevy calipers can take quite a bit of grinding because they are of the single piston design. I have helped grind several that I thought may be too thin and they are all still working with no problems. I think you will be fine
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I ground the **** out of mine and around the hole in the center is about 1/8" thick but it gets thicker as you go away from the center. I also removed about 1/2 of the plate that locks the caliper in place and I have had no issues with mine.
    Ira
  8. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I'd be willing to bed that its just fine. If worst came to worst, you can always get 15" wheels with 2.5" of backspacing, as those require NO caliper grinding, and they look cool/ stick out farther past the fender wells.
    you could always just mail those 35" boggers to Georgia, heck you could even leave the dana 60 attached :haha:
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i run 3" bs and didnt worry about much grinding :)
    you should be ok, if not, who needs brakes anyways?
  10. HELLBENT DESIGNS
    HELLBENT DESIGNS 1/2 ton status
    Apr 2, 2005
    453
    bozeman mt
    the metal does get thin at the edge of the hole but if you look it gets thick very close to the hole ( like thicker then your thumb) you will be fine:D
  11. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    sandawgk5- the clip that goes on top of the pin- how much of that did you have to grind?
    So, best way to go out and test them? Just romp on the brakes a few times and then check for cracks or what?
    Thanks guys! Most of the wheeling up here is up the side of mountians...... so of course you must come down. The pucker factor on some of the down parts is bad enough with brakes you trust. Leaves you tasting seat cushion for a little while. :rolleyes: :D
  12. sandawgk5
    Oct 28, 2003
    6,881
    I took more than half of the top of the tab away. The other part is still between the bracket and caliper so I am not worried about it.
    Ira
