d60 caliper install help
Discussion in 'The Garage' started by muddybuddy, Mar 23, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    alright i know that i need the pin and bolt and all that, but i cant even get them in position...any help would be great. thanks
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Umm, can you elaborate a bit more, that description isnt near enough to help...
  3. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    dude with all the problems you are having just ship it to me.:haha:
    just need to wiggle in the correct spot and bam it will pop in. i have trouble with mine from time to time. :wink1:
  4. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Are you having trouble getting the torx bolt or the pin in? I mean there really isnt much too it. Just hit it/fiddle with it, youll get it.
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    im jus having a hard time getting it in the brackets, the corner of the pad on the piston side always hits, i tried jus smackin it, but didnt do any good. i thought bout grinding it down some, but i duno. ive been workin on the truck for 5hrs straight, so im gona call it a night, and continue playin with the calipers tomorrow haha.
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Grinding? There is absolutely no reason for that. Are the pads in there correctly? I dont even see how the pad could really be that much of an issue.
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    its the corner of the metal part, maybe its not in right. there arent any of the spring type things to keep them in place. maybe thats the problem? i did a search and it didnt seem like they were needed, but what do i know, this is my first 60
  8. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    There are springs for sure, how else would they be held in the caliper..
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i mean at the ends
  10. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    I still dont understand how the pads could be causing your problems. When I had my 60 the hardest part in getting the calipers back on was just getting that pin to go in. Take the pads out and see if you can get the caliper to go on. That will narrow things down...
  11. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    wait, i havent been tryin it with the pins and the other thing. should i be able to get it pretty much set then slide the thing in a bolt it in? or is it never going to "set" without puttin the thingys in?
    sorry for the retarded language, i duno what to call it
  12. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    The pads can lead to a problem if you have a sticky caliper, push the piston all the way in, maybe some lube too.
    just a thought, my old calipers are well old.
  13. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    Why arent you putting the pin and bolt in? The caliper is going to sit a bit funny without that pin in there. Set the caliper in there and put the pin in, that will get the caliper in there right.
    I was assuming he would have ruled that out but yeah that would give you a bit of a problem. :D
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    :doah: alright, i thought it would set in place and i could take my gland old time sliding the pin and bolt in. now i know :D hopefully that solves my problems
  15. 81jimmyslt
    Jun 5, 2003
    1,643
    whos got a link to the post with pictures floating around that shows the caliper install on a 60?
    That should help
  16. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    that would help a lot
  17. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    here's one showing the what's visible with the wheel on.
  18. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks for the pic. i figured it out in 2 sec once i had gotten some sleep. thanks for the help guys
