D60 carrier problem
Discussion in 'The Garage' started by short sub, Apr 28, 2005.
  1. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    i just installed a new carrier in my D60- i used the same shims as it had before and followed the instructions as Detroit tells you to. I just went to install it and with the bearing caps on it has roughly 1/2" gap on both sides??? This unit is outta my friends 87 D60 and mine is a 77 model. I dont think that the differential would be different between the two years, but how could it be so loose within it? I have had the axle apart many times but i am stumped as to why its doing this. On my previous carrier, for some reason the bearings could slide off and on without needing to be pressed so thats why i changed it- could that have an effect on something now? appreciate the help Thanks Ryan
  2. dan dibble
    dan dibble Registered Member
    Apr 30, 2004
    30
    collierville TN.
    There are two carriers availible for the dana 60. 2:73-4:11 then 4:56-7:17. I bet this is your problem. Ring gear placement is the difference. Lift your old carrier up to the new one and compair them.
    Dan
    Or one of the axles may have been a 61 but not likely
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    So theres 1/2" between the bearing races and the housing? The case splits shouldnt effect the overall width of the detroit, but where the ring gear mouts(more to the right if its a slow case).
  4. dan dibble
    Apr 30, 2004
    30
    collierville TN.
    Yes, the bearing surfaces should be the same. I somehow thought he was talking about the gear.
    Dan
