D60 Crossover????--ford van pitman arm??? NEED HELP FAST!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SCOOBYDANNN, Aug 7, 2002.
  1. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I've read hear and there that a ford van pitman arm will work for the crossover on a d60---i went out and got one from a PNP and it looks like it will work but the taper for the tie rod end is too small (ie its tapered for a 1/2 ton, and i have a 1 ton TRE on the draglink) what can i do---get it tapered for 1 ton or just drill it out and put a heim in there?---problem w/ getting it tapered is im having a hard time finding someone to do it, and i already have an in w/ a guy to get heims.----my truck is amlost ready i just need to get it outta this guys shop
  2. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Went through the same issue. What you have to do is find a machine shop that has the taper. I found one and it cost me $40 to have it tapered for the 1ton end. Just bring the pitman arm and the 1ton end to a machine shop and ask them if they got the taper for it.
  3. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    Yep! I have a taper tool. I had to do the same thing. To get the 1-ton joint to fit. /forums/images/icons/tongue.gif
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Just get an '78 or '79 F150 4x4 drop pitman arm, like from Superlift, part no. #1104, and be done with it. /forums/images/icons/wink.gif
  5. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    What are the advantages/disadvantages of tie rod vrs. heim?
  6. Waxer
    1,857
    Long Beach, CA.
    tie rod = less expensive and better availability
    heim = easier to install (thats about it) /forums/images/icons/smile.gif
  7. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    so if you use a ford pitman arm you can use stock 4 wheel drive box
    or are using the 2 wheel drive box?
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You have to have the 2wd output shaft to use the ford pitman arm.
    BTW, my pitman arm was reamed out for the TREs...
