D60 Crossover + Zero Rate Forward
Discussion in 'OffRoad Design' started by BBlazerSK5, Apr 12, 2004.
  1. BBlazerSK5
    BBlazerSK5 Registered Member
    Feb 9, 2003
    20
    Cheshire,Connecticut and Rochester,NY
    /forums/images/graemlins/1zhelp.gifHey guys, well i am just pulling my rig in after winter, to put on my ORD crossover steering and highsteer arms. Thing is, i want to put my Zero-Rate Add-a-leaf up front and push the axle forward 1.5" to extend the wheel base just a little bit, at the same time clearing the fenders a little more. It has 6" TCI front spring and the HD Extended ORD greasable shackles, with the crossover steering and highsteer arms, how much can I move the axle forward before I run into contact problems, or any other forseable issues that I missed.
    Thanks /forums/images/graemlins/dunno.gif
  2. BBlazerSK5
    Feb 9, 2003
    20
    By the way heres what i have and will be installing by mid-May:
    1989 K5 Blazer
    Rebuilding 350 TBI
    Comp Cam #114102 (500-3500 RPM)
    Headman Headers
    Flex-a-Lite #295 Electric fan
    Dana 60
    ORD Crossover Steering
    ORD High-steer Arms
    ORD Greasable Extended Shackles
    Detroit Electrac
    Genuin Gear 5.13's
    4WD Factory 35 Spline Kit w/ Warn Premium Hubs
    6" Tuff Country Springs w/ ORD greasable bushings
    1" Zero-Rate Add-a-Leaf
    High Angle Driveline 241 Slip Yoke Eliminator Kit
    AZ-Kickin Disc Brake conversion for 14B FF
    Precision Gear 5.13's
    Detroit Locker
    BushWacker Cut-Out Fender Flairs
    4" Rear TCI Springs
    4" ORD Shackle Flip w/ ORD greasable bushings
    Steel Braided brakelines all around
    Greasable Everything
    ORD Weld on Steering Brace
    ORD Bolt on Steering Brace
    Ranch 9000X's (RS99012)
    38.5x15x16.5 Super Swamper TSL's
    New Chevy Silverado Charcoal Grey Paint Job
    I don't Think i missed anything, This has been my project for the past two years since i was 16, now for my senior year i finally get to wrap it up, and i think it will be one of the sickest Blazers out there. /forums/images/graemlins/peace.gif /forums/images/graemlins/k5.gif
  3. 96chevysfa
    96chevysfa 1/2 ton status
    Jan 1, 2003
    230
    so cal
    my truck is not the same as yors, but i run 6" skyjacker springs, a 1" 0 rate moving axle foward 1.5" and ord crossover with the d60, and i have no problems at all.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The problem you run into with the crossover highsteer is that the pitman arm can get into the tie rod, so I'm not even sure you'll be able to run the axle offset 1". The 7" of lift might get it high enough to work, but I think the 1" will be the max, if you can move it forward at all.
    I thought I had a pretty cool K5 for a highschooler and all I had was a stompy 383 in a 3" lifted '82 K5, you really do have a cool K5!
  5. BBlazerSK5
    Feb 9, 2003
    20
    Thanks Stephen...I will pay attention to the pitman arm and rod end as goes in. Probably start at 1" then see if i have any room left for more. /forums/images/graemlins/waytogo.gif
